Shawn;
no, i've always used big Victor 2 stage regulators
Kev;
ever try brazing all the way around a mitered tubing joint angled say 30deg with a MECO in one pass?
you can't because the torch is basically flat and you can't roll it in your fingertips
did you see where Kent at tinmantech holds his MECO with visegrips when it gets too hot
what a hack......
and the short screw on tips make a less focused flame and work on a narrower pressure range
you even think about picking my Purox up without asking......i'll beat you like i own you....
used the same one for 54 years, knurling is perfect, no scratches or dents, no bent valves, no wrench marks......just rub marks from my fingers
you hand me a Purox 00 blindfolded....
the gas valve is the forward one.....i want it on the left
i check the tip, i want it facing away' i crack the acet with my right thumb and index finger....pop the striker
add oxy with the same fingers.....i can get close by sound.....but give me a break
the Henrob is even worse on tube structures.....think about it.....you can't rotate it in your hand at all
