jimzz2006
My 2001 caravan was sitting for a while- 6 months.
started it up and went to drive and the rear wheels were seized.
Rocked it back and fourth and one side freed up but the other took a little more persuasion dragging it on the asphalt road. wheel got enough traction and eventually it popped.
Took it for a ride and the rears were grinding bad. So i figured new brake shoes were in order.
Before getting started i got everything I could think of. drums, shoes, wheel cylinders and new spring hardware.
I have NEVER done rear brakes before. Fronts yes but never rear shoes.
so far i have 1 drum off-- it was a *****. Like I said I got new ones so I ended up taking it off with the 4" grinder and cutting it in 1/2.
The inside was rusty, gunked up, nasty. Got the old springs/pads off and got the backing plate cleaned up. But now I am stumped.
The lever for the E-brake. how does that connect to the pad. IT just came off when I removed the pad, well it was still connected the the E-cable.
I cannot see a clip or anything that holds it to the shoe. Do you just get in place and the springs and nails hold it in there?
Like I said i have never done rears before.
