OHMS LAW
Using a small vacuum pump, what would I need to recover, besides gauges
Well I am trained in ac they wouldn't sell vac pumps for the process if it wasn't safe..
I'm asking because I'm new to the trade, I'm trying to do my brother a favor, it's why I asked before I did it. That's what this place is right?
Is it even necessary to recover 134a from a vehicle? Seems that it would be a moot point seeing as how much you would actually recover.
Sent from my DROID X2 using Tapatalk 2
Yes, it's required by law that R134 is NOT vented to the atmosphere. The only way to remove it without venting it is to recover it. The fine starts out a couple grand if the EPA finds out you release it to the atmo and goes up depending on how much. more if it's done at a shop (or school) and if you're licensed/certified you can lose that.
BTW R134 is being phased out as R12 was 20 years ago. Soon enough it won't be manufactured anymore and only old stock and recovered refrigerant will be available like R12.
Trained in a/c and doesn't know what the difference between a recovery machine and a vacuum pump are...
yeah, that's some crazy **** right there....
Bet he throws in one of those "hail mary in can" leak sealants into the ac system from wallymart before it's all over with...![]()
I ask since I seem to remember one of those little pressure bottles for dusting your keyboard was actually a small can of 134a.Yes, it's required by law that R134 is NOT vented to the atmosphere. The only way to remove it without venting it is to recover it. The fine starts out a couple grand if the EPA finds out you release it to the atmo and goes up depending on how much. more if it's done at a shop (or school) and if you're licensed/certified you can lose that.
Thanks for the responses. I was able to use a Robinair recovery machine at my school and no mr Tar Heel I'm not some dumb kid, that's why I asked, instead of posting an "oh **** look what I did help" thread. But either way I'm installed and blowing cold with out the use of your autozone sealant.
The EU is now phasing out R134a. US auto makers have until 2017 model year then need to use the new HFO-1234. There will still be a need for R134a because it's unclear if the HFO-1234 can be used as a replacement in a R134a system. My understanding is there will most likely be no ban on R132a but possibly a high tax/fee tacked on to the price to discourage people from buying it to fill leaky systems instead of having leaks repaired.
