Tips for welding;
1.Vertical-down = high amps/voltage; rod angled down 5 degrees below horizontal, or more; fast speed. Good for welding sheet metal, or making a cosmetic past over a vertical-up weld. Does not penetrate very deeply!
2. Vertical-up = low voltage/amps so that it will just hold an arc comfortably; rod 5 degrees below horizontal; two passes needed with a MMAW and probably the same with a MIG; very strong weld excellent penetration.
First pass - straight up no weaving, if using MMAW, ignore the dribbly mess the slag makes; chip slag inspect for an even bead of metal. Lumpy bits means you went a bit too slow or that the amperage is too high.
Second pass - Same amps and rod position; a weave needs to be done, there are two methods I have used the fir-tree and the U-shape. This is really only explainable with a diagram; however; with the U-weave the arc is established and drawn across the work the edge of the weld area, at the same time call the timing to yourself 2,3 at the end of the 2,3 bit weld upwards for about the diameter of the electrode calling the time 1; then come back down to to where the 2,3 bit is and go across 2,3; up 1 and repeat the sequence. Going up 1 allows the 2,3 weld to cool enough to support the next run of 2,3 next to it going the other way.
The fir-tree involves the horizontal pass 2,3 but instead of going up on the 1, the electrode is taken diagonally up to the centre of the the first pass and then diagonally down to where you started the 2,3 bit; and then the process is repeated. When drawn on a bit of paper the overlapping triangles look a bit like a fir-tree hence the name.
I haven't done a vertical-up MIG weld, but I see no reason why this shouldn't work.
D_rock you will need to use vertical up if you are welding structural bodies,
Cheers Charlie
