Is my Drywall repairable?
EAC
Wildwood, MO
Sorry if this is in the wrong spot or wrong forum. Figured there are a bunch of smart folks here, so thought you could maybe help.
We had a little soft spot in our drywall next to our shower where the shower glass leaked a little over time. I scraped away the soft spot and found this. It's hard...
Here is the deal, we're going to do a complete bathroom remodel next year, which includes tearing out the effected wall.
Is there a temporary fix until next year?
E
EAC
Wildwood, MO
Yes it's fixable, first fix the leak, then use either fast setting drywall mud or Johnon's hard as a rock fix.
Right, I extracted all the old **** and gonna lay more **** down tonight. That was the only issue.
Should I remove more of the drywall or is that enough?
BlindViper
York, PA
I really don't care but its caulk...might look funny if you asked which kinda **** you need :)
Big-Foot
Midlothian, TX
If I was going to tear it all out soon, I would just mud it in, sand, prime with oil based primer, then a coat of semi-gloss paint. Then caulk it and clean things up if they get wet..
Toomanytools?
Washington
Wow might have to delete my post I want nothing to do with your **** issues.:headscrat
dirttracker18
Slate River, ON
I would cut that section out and put a new piece in, tape mud and paint and it will last.
that will also give you a chance to see what is happening inside for the upcoming job.
Mudding over that mess might not last the year you need.
It will be less work to put up a piece then to try and mud that area and make it look flat.
JMO
CNGsaves
KS and OK
Yes, cut it out to get rid of the mildew. Don't touch it with your ****.
. . . . AND . . . don't decide to then go spray on pickup truck bedliner, get your hands all covered with bedliner material . . . and then, have to take a whizz !! :D
Twiggss
middle
This just needs to be quoted one more time.
Kels
Silverdale WA State
My day was just so so, I'm at work and just about ruined my keyboard reading this thread! lmao :D
Make sure the leak is fixed so that you know your problem isn't way bigger next year.
Tim The Tool Man
Lehigh Valley, PA
Okay everybody needs to quit playing with their **** guns and help this man. First remove hand from ****. Next put it away. (Please!)
Okay now it looks like you have and old brown coat/skim coat wall and not drywall. So I wouldn't take anymore of it out as long as it is now dry and no longer crumbly. I would mix up a small batch of hot mud (powdered) and fill the void. Then sand it, prime it and paint it (latex is fine) then **** the joint where it meets the shower door...
E
EAC
Wildwood, MO
HAHAHA!
So, the brown color isn't water related?
Tim The Tool Man
Lehigh Valley, PA
"Brown Coat" is what the base layer of a plaster job is called and the grey looks like base coat plaster (at least on my computer screen) but I cannot enlarge the picture to get a better look. The red-ish brown more toward the corner looks like rust from the mesh corner bead. You'll have a very large mess if you try to rip that section out. Use a Killz primer over it. Again if this area is dry...
wssix99
Chicago, IL
I don't know what the big deal is. Just stick a **** in the hole
images
and then mud right over it.
my68spit
Illinois
I come in here expecting professional advice on drywall repair and all I am left with is a nasty looking brown hole with **** in it. WHAT IS THIS FORUM COMING TO??!?!?!??!!! :lol_hitti
srmofo
SW ohio
Quoted for posterity....sitting here LMAO off at all the other posts
DIC
If you extracted too much **** You will may be laying **** all night :D
wssix99
Chicago, IL
You guys certainly milked that one for everything it was worth :thumbup:
And i'm still wiping the tears from my eyes from laughing so hard
Better tears than **** residue. We've forgotten all about safety and how important it is to wear safety goggles when messing with **** in these types of situations.
CNGsaves
KS and OK
Cobra6
Tennessee
JMO
This -
and I am trying to ignore the other posts, but they are funny :lol_hitti
pablo21
Cut out all the damp stuff, make sure all the surrounding areas, including behind the drywall are dry, then put in a new section of drywall.
No point in mucking about, just get all the damp stuff out or you'll end up in the same position somewhere down the line.
