protecting bare metal tools
steveo3002
cambridge england
ive got a few old tool that are bare or the orig plating has worn away
is there something i can use to protect these that wont make a mess or stink up my hands , up until now i wipe em down with a oily rag but i marks the tool box liner and isnt nice to handle
nine4gmc
Dallas
Wax for wood, metal, sealed leather, plastic, sealed cork and vinyl. No greasy feeling after wipe down, lasts long and easily re-applied. I use a sponge pad and apply a thick coat, making sure to get in all the cracks and crevices, then wipe down with a clean dry shop rag.
sGIv0Ar_Vr7shPgP7VL120xAnHXDDmdshi0MqndWyjdg4uwczdrFPHpVuSQsoek2D9I79MsLuQ3oT_V-5ztnBi69RFcpV27HrvfPQW3t6LCgLfGwL-6Emi-kNK-bEgDokGDrLiv2LmernNYqUWWICNdHo3WbLYIEx944OwhauQ=s220-c
woody 73
The Great State Up North
:thumbup::thumbup: Good advise.
Woody Tip: if you want to remove the wax just spray them down with some WD-40 and use a rag to clean them up; although I am not sure what they call WD-40 in England ? If you don't go with paste wax then wipe your bare metal tools down twice a year with an old rag soaked in machine oil.
zkling
same thing..we have wd40 here ..shame no pb blaster
Well its good to know that WD40 distributes their **** globally. :lol_hitti
nine4gmc's suggestion is a great one. That is what I use on all wood power tools. Drill press surfaces, jointer surfaces and table saw surfaces. Your local equivalent of paste wax should be good. See what your local wood workers are using.
This may sound strange, but how about a quick clear coat? Paste wax doesn't really have the oily texture that a oil damped rag would, but it does have a smell to it. I am not sure how it would hold up to tools that are routinely used. What are you trying to protect them from, rust?
jakemac
New England
I use Blaster corrosion stop. Spray on wipe it off, it last a long time
^^^^ This ^^^^
I had been using 3-n-1 oil, but lately I've taken to wiping everything with PB Blaster. I learned the hard way that WD40 ends up promoting rust as it dries out. Years ago I use WD40 on all my tools. 3 months later I was having to wire brush my whole toolbox.
d.mcfarland
Western PA
I think the OP needs to be more concerned with maintenance such as reapplying oil or wax. It only lasts so long and that's what most people forget.
Bugeyed Earl
Davie, Florida
I use this stuff inside bicycle frames, and on some tools also, good stuff!
I've also use boiled linseed oil on some tools, and just yesterday the hazard of using different treatments became apparent: I grabbed the head of a big lopping shear that I thought I coated with linseed oil (which gives a dry finish,) and got a big greasy handful of Blaster :mad:
ilovevocs
Toledo, Ohio
I use corrosion X.
http://www.corrosionx.com/corrosionx.html
All of my seasonal toys like my bikes and snowmobiles get a light coating of this before going into storage. Have been doing this for the past two seasons with my new sleds after purchasing them new and have no signs of rusting of oxidation on any of the surfaces. I have never had a sled look so good for so long. I'm a real believer in this stuff. A little bit goes a long way, and it smells fantastic. The only exception on my sleds is the clutch faces, I wipe them with isopropyl alcohol.
Bruce Lancaster
Wax...no mess, lasts, doesn't chip off or slime everything around it. I use Butcher's floor wax...lay it on heavy, wipe it down after a while, done. Great on any tool that lacks plating and that is used in such a way that paint will be destroyed...
HighPlainsWrencher
I like to use multi purpose grease, 5w/10w engine oil, sae 30, 75w or my favorite 10w hydraulic fluid. Apply daily wipe clean weekly use parts cleaner as needed.
beerdog
Buffalo Grove, IL
I use this special oil for firearms. I can't find the can so I I can't tell you the name. It comes in a small can. It is suppoed to displace moisture. It penetrates, disolves rust, and cleans very well. You can find it almost anywhere that sells firearms.
GRX
MD
Wax x3 ... Lemon Pledge (or similar). Been using it to protect tools, bare machinery, and newly machined metal surfaces for years.
