Is there a plastic pry bar out there??
mroneeyedboh
I was thinking, when you remove the lug nut covers on cars ( like in my case, an f250 ) they are plastic chrome. When you use something like a metal pry bar they usually get those indents on the edges from prying. Is there a plastic prybar out there or a no mar prybar?
kerryt1
Oklahoma
mroneeyedboh
The are recessed here is a picture
Uploaded with ImageShack.us
I think I need something like an angled prybar. And these things are on the lugs TIGHT!
mroneeyedboh
Im wondering if the snap on ones are guaranteed. If they are then I dont mind spending the 45 bucks
Big Pete
Go to Wall Mart or Target and get a couple of the flat wooden food stirrers. If you need more of an edge they sharpen up well on a belt sander or even a file. They are also pretty decent gasket scrapers for ally sealing surfaces.
jjjrmx5
Cincinnati, OH
Sure, window guys use some plastic pry-bars. Do a search, I know there are Snappy sets you can buy.
Snap-On for that? Ha.
They just rebrand from others and jack the price.
Buy the yellow plastic trim tool set from Harbor Freight and be done with it.
In fact buy 2 sets.
They come in handy for bicycle tire changing tools as well as for other prying needs.
I bought the SO set and promptly returned it. I guess 3/4 of the cost is in the fancy tool roll it comes in.
And I'm a SO fanboi BTW.
Brownsfan
Cleveland Ohio
Like paint bucket ones that HD gives you?? I have a few in the garage.
edited:
Im wondering if these can be used on trim panels too, or are they too big?
Yes they can. I use them for interior panels all the time. Pretty much all I use them for. They are worth the money. The cheap HF ones just break apart and chip. The snap on ones do not bend and break like the cheap ones.
Brownsfan
Cleveland Ohio
Holy ****! $44 for 5 pieces of plastic made from recycled milk jugs! I'm all for Snap On, but that set better come with some lube.
This set is well worth it if you work on interior panels a lot. I grid the HF set and they just bend chip and break when you try prying stubborn panels. I have all 3 sets snap on makes. They do not bend or chip apart or just break in half. I have had them for about 2 years and have not had to replace one. The HF set I would have had to replace the whole set at least 4 times in a 2 year span. Buy quality once.
aczr2k
NW Minnesota
The HF set is complete junk, I've broken tips off all of them. Now I have the large Bojo set, way better and worth every dollar. My set was few years old and yellow in color.
Tarheelgarage
NC
JerseyBoatBuilder
Florida
If they are attached that tight then I would get the Ultra strong or extreme bojo pry tool
Look on their site and buy a single pry tool that is shaped how you require it.
My work bought a few sets of the Blue harbor freight pry tools the material they are made out of isn't that hard while they do not mar surfaces the tips of the tools beat up, chip and gouge easily after a few uses.
They are garbage for heavy use compared to the stronger hardness Bojo pry tools.
The Bojo non marring pry tools are available in 4 different hardness's
