B18c_tuner
- Joined
- Jun 27, 2012
- Messages
- 167
I'm looking for some one local to have my tool box shadowed. So who would you guys recommend here in southern Cali?
Snap-On dealers will do it if they have access to the shadow box...do it yourself though and make sure you're happy with the way the tools are laid out! I think my Snappie guy said it was 100-150 bucks a drawer...100-150 reasons why I spent an afternoon in my garage with a razor blade, pencils, and a few different colors of Styrofoam.
I think I will go with foamforyou.com as far as the foam. But am still not sure exactly where to get the foam cut. I figured since I'm spending money for the foam might as well get it professionally cut for a proper look. I've looked into methods of doing it myself but I find it would be a waste of money if I couldn't get the tools to fit/ sit properly in place. As far as the box I'm using, it's just a cheap cantilever box. So the cost would be small for sure. As far as space goes I'm planning on putting just your absolute basic tools so space is not an issue.
Mind if I ask why you're shadowing? I know some jobs require it but some people do it for their own purposes as well.
One of the mechanics at my airplane partner's shop showed me his new tool chest and how he had shadowed it, if that's the correct term. He had use this foam that you can tear out these small pieces, cylindrical pieces about the size of a spaghetti noodle. Or perhaps smaller, it's been a year or so. You would lay the tool on the foam and outline it with marker pen [or he did], then lift the tool and carefully pull the fibers withing the outline. It looked as if the foam had been cut, it was very clean. It also looked crazily time-consuming. No idea what it was, I assumed [being a shade-tree DIY sort of mechanic] that it was some common foam everyone else knew of. But there didn't seem to be any cutting of foam involved. He bought it from the tool truck guy.
Plain and simple. I have the money to do it. And I can care less what people think on waste of space, waste of money, etc. The bottom line is I'm gonna be using it and no one else on this board will. As far as better tools, Snap-on is the best as far as USA made tools are concerned. But thanks for the info guys.
Thanks for the pics. Your shadow skills are great. I'm not sure if I can even do as good a job as you. But I will definitely send foamforyou.com an email regarding their cut service. Although I perfer to physically be there to set the tools on site before cutting the foam.
If I get a chance, I might try it on my own toolbox.
I have a Universal Laser Systems VersaLaser VLS 4.60 LASER engraver amongst my home workshop tools. Mine has a 24" x 18" work space, so it'll easily handle the size of inserts in my tool cabinet.
I suspect that if I aranged the tools on a matching size backing, and took a photograph of the layout, it shouldn't be difficult to transfer the data from the digital photograph to a cutting file for the LASER.
Option 2 would be to construct a simple vacuum table as large as the tool box insert, arrange the tools on the vacuum table and do a vacuum molding of the tool layout using thermoplastic sheeting.
