Drill Press turned wood lathe
lucky.expert
San Antonio, TX
I needed a big round piece of wood to build a lamp, but of course I don't have a wood lathe to turn one. I am going to be wrapping the piece of wood with little sheets of aluminum to give it an aviation type look, so the wood doesn't need to be perfect, just nice and round. So I start thinking and decide I can turn my drill press into a temporary wood lathe. I built a little bit with little 'claws' to get a good grip on the top end. On the bottom end, just took a bearing and put a bolt through it. Ground down the end of the bolt to make a point, so the bolt spins with the inside of the bearing. I secured the outside of the bearing to a piece of wood, and so that's what holds the bottom of the wood piece. The wood in the picture is 4 2x4's glued together to make a hollow center. I held a skill saw sideways to get the general shape (probably not the safest thing I've ever done). It's not perfect yet, i need to use some files i have to get the diameter equal from top to bottom, but you get the point anyways.
kbs2244
Do a search.
It has been done before and you may get some ideas.
InPrimer
lake Havasu AZ
ever consider a 4" or so hole saw, used by plumbers usually to cut drain pipes etc. Can be stacked to desired height and glued up. The pilot hole from the saw will be big enough to thread the power cord.
Twitchr
Nice, good idea. Works in a pinch!
Is that a plotter in the background?
Jim Johnstone
Brantford, Ontario
Sure looks like it. Now I am curious too. Is that a drafting plotter or a vinyl cutter?
Sent from my SGH-I727R using Tapatalk 2
L
lucky.expert
San Antonio, TX
yea the octagonal shape would have been a good idea, I could have used the table saw to do that. I'll remember that for next time, knocking the corners off that thing wasn't fun. I would love to have a real wood lathe to do it right, but wouldn't use it enough to warrant taking up the little space I have right now.. I'll post a picture of the finished lamp once I complete it to show what i needed this redneck wood lathe for.
And that is a 24" vinyl cutter in the background, but the knife can be replaced by a pen so it is a plotter too. It sure is handy to make my own decals for my different projects, I used to do some custom work so it has paid for itself.
RetiredOldGuy
So. California
For future projects you should know that the larger landscaping/gardening centers sell "peeler core" logs for landscaping projects. Peeler cores are the center of the trees they peel to make plywood and are anywhere from 4-6" in diameter and 6 to 8' long, depending on where the are bought.
But, if you still would need to make them bigger , or smaller, buy yourself an old Craftsman 36" wood lathe and mount it to a good plywood board. This lathe uses a round tube for the ways and is belt driven with almost any 1750rpm motor. You can find these lathes at yard sales or on craigs list for almost nothing. It is small enough to stand in a corner when not being used, then bolted to a table or bench when needed.
Drill presses are not really designed to take lateral loads, although your occasional antics most likely wont hurt it. Wood lathes are fun, almost therapeutical once you learn the basics.....
Mike
LXCam
Hey the project turned pretty cool, I like the way you cladded it. Hold on, is cladded even a real word..hum
Radio Ron w4ron
Radio Heaven (near Charlotte NC)
Good job. I've used the vertical drill press at work many times as a vertical lathe
for making small parts when I didn't want to mess with dealing with the jerks
in the machine shop.
I liked the challenge of figuring out how to do it my way.
