Hey everyone I have a idea in my head for making a slip roll to do a project but I am not well versed in slip rolls,
I am looking to put a curve in 1/8" or 10 guage mild steel that is going to be about 6-8" wide.
I know I will need larger rollers, but I don't know what size. I am guessing around 3".
Instead of using solid steel for the roller I was thinking on using pipe and having two endcaps (for each roller) made so that I can use a pin that will go through the roller and into the "frame" of the slip roll. For extra stability I was considering filling these with cement. I was hoping the pins could be .75" diameter vs 1" just to make drilling those holes a little easier.
For compression I plan on using a bottle jack or maybe making it to fit inside a shop press.
Some questions I have:
Are all the rollers the same diameter?
Will having only 1 roller "powered" be enough to draw the material through?
How thick should the sides (frame) be? I would think this would bear most of the force. Would 1/2" material do?
This is all I can think of if anyone has any insight I would greatly appreciate it.
Thanks,
Ryan
Thanks,
Ryan
