Who's got the largest file? Come on and show them off.
rusty65
Pekin,IL
Here is my big file it belonged to my great uncle who was a welder for the rail road and would go around and fix the low spots on the tracks by building them back up. Those are indeed 8in crescent wrenches the file measures 22in long by 1 1/2in wide with the handle on. So lets see them who's got the biggest and the baddest file around.
zoomieport
The Mall City
One is 18" x 1-5/8"
The other is 22-1/2" x 1-1/2"
I'm assuming you can figure out which is which! LOL!
R
rusty65
Pekin,IL
Nice looking files zoom and Jeep. I assume the rail road industry and large machine shops are the main users of the large files although the large files are very useful for removing a lot of material quickly and efficiently.
OK I'll play, but FYI, the correct way to measure the length of a file is from the tip to the heel (where the file starts to narrow for the tang)
And I need to start the "inventory" process for my files, and it's easier to start with the big ones, (I have fewer of them)
But I'l work up to the big'uns I have.
Oops, hit the wrong button, pics now...
Some 12 inchers
Some more 12 inchers
Some 14 inchers
and the 16's (With one more 14" farriers file. The back side of that one is the nastiest rasp you ever saw for cleaning off hooves.)
I'm not too sure anything bigger is useful, as there is a practical limit to how long a stroke the average person can make physically.
what lines of work use them this big?
It's not so much the line of work but moving a lot of materiel fast. I have used these a fair bit and I use the smaller files when I'm working between things or in gaps. so I also have a lot of smaller files as well as files I've needed for really narrow spaces or holes.
jakemac
New England
16" *******-cut square file, 23-5/8" long with handle.
I have 2 of those files. I call them my "Hoggers" because they hog away the material in no time.
I have a bunch of large course files, back from when I did a little blacksmithing. Unfortunately, most of them are in my smithing box buried in the back of a storage unit.
They're great when you need to remove a lot of material, but you need finer files to do clean-up. For Whitesmithing (yes, that was a profession at one time, did you think that the Blacksmith did all his own finish work ?), I like to use worn-out fine files. It takes more time to get the job done, but saves time on polishing. (of course electricity and die grinders are much faster)
So while we are talking files, who has some new ideas for storing or racking them?
I used to have some of these on a simple aluminum angle (actually a piece of step edging the curved part made a decent "hook" to keep them from vibrating of the rack), with crude notches for the tang, and they hung from the handles (you have to keep the handles tight or risk having a file drop out and hit the floor...)
I never put it back up after moving as 1) I out grew the available notches, and b) It's pretty crudely made, and I want it to look decent.
Drawers are not an option, I have one drawer in the Kennedy top that is bursting at the seams with smaller files, and some more tucked in another drawer, and these are too dang long for a std tool box drawer anyway.
Suggestions?
Plombob
Tennessee
Suggestions?
Years ago, Snap-On offered plastic wrench racks with sticky tape on the bottom. They work great for files. Don't know if they are available anymore.
WWIIjeep
Arizona
At work we had a wall rack made of 2" aluminum angle-iron with slots milled to hold files by the handle in the manner you mentioned. We gave the front edge a slight "kick" upward in a sheet metal brake to keep the files from sliding off the rack accidentally. It worked great and looked good. Alternative to bending the front edge, you could either tilt the rack slightly with a spacer behind it, or add a small curb to the front edge between the slots.
Another way might be the way I store wood lathe turning tools and the way we stored taper shank drill bits, which is on angled wooden wall racks with grooves or dividers to separate the individual pieces and a front rail a few inches up from the bottom to keep stuff from tipping out accidentally. Works great for wood lathe turning tools with long handles, and for taper shank drill bits, but I think it might be a little awkward for files and not really the best way to store them.
I think drawers are the best option for small files. I've got a drawer in my Gerstner dedicated to Swiss pattern files and ignition files and so on, and two drawers in my work bench for medium and large sized files.
Now that I put a handle on that 16" square file for the "contest" I'm going to have to make at least a short rack like the one at work, because with the handle on it, it only fits in the drawer at an angle and gets in the way of other files. :( Before yesterday, I just had it stuck in the back of the drawer without a handle, because it's not one I've ever really needed to use except for a largest file contest. :lol:
Yep, smaller files I'm good with in a drawer or drawers, just these monsters need something else...
You need to use the big guy and you will be amazed at the difference in both speed of material removal and control of the file using a longer file...
MikeF2316
Thornhill, ON
A little late to the thread, but definitely a contender. This was my dad's, sometimes he liked to use a cheap handle. One of my smallest files is included.
Gidge
New England
Mine max out at 14" according to Outlaw's method of measurement.
