Tyrol67
Planning on installing a Takagi JR tankless water heater for in slab radiant heating. It sure would be great to get hot water for washing equipment out of the same system, but I plan to keep anti freeze in there for the heating system. So, I have two thoughts. 1. Disconnect the heating system for the summer and use the heater for hot water only or 2.) Is there some type of heat exchanger set up that would work where the ant-freeze solution would be heated by the heater and provide heat to the heat exchanger. I am thinking that solution 2 gets a bit complicated. Can the heat exchanger truly provide instant hot water, can it handle the thermal shock, etc. Since I won't necessarily be in the garage routinely, I don't want to risk running without anti freeze. I also realize that mixing propylene glycol with regular water is not advised, though I don't plan on drinking it
Has anyone had any success with any setups?
I'm not sure if they're just trying to sell boilers! The JR seems package appears to be available at a reasonable cost...
