i'm tying to resurrect a poorly built garage by starting at the bottom. the original floor is probably as much as a foot thick in some areas, it has no cracks but it is not even remotely level or flat! the garage has a tall foundation wall (about 2' above slab) and a "floating slab" inside. my concrete guy says "no problem" he can pour on top of it with a barrier to separate the two slabs. i would like to run tubing for radiant heat in the new slab. my concern is insulation. i don't have head room for a bunch of foam between the two slabs. also what about between the slab and the foundation walls? the more i read about bubble wrap under the slab the less i believe in it. I've researched a fair amount but i haven't seen this senario. thanks for any input.
Scotty T
Scotty T
