dipan
This is from my post on candlepower forums where I first learned of the concept of soffit lighting. Thought I would share here, though ...
I have selected locations around our relatively large house for 25, 40, and 60 degree optic'd 3 watt Cree XPE powered prebuilt recessed lights and have installed some of them. The fixtures themselves are from superbrightleds and look well made and appear to be have a cast aluminum body. Pretty well sealed but not waterproof or anything, but should be reasonably protected from rain by the soffit and overlying roof/gutters. They are all working since the installation about 6 months ago. These will be primarily accent and slight intruder deterrent type lights. We also have floodlights that will be motion triggered if someone decides to walk up to our property.
Here is the fixture:
I drilled 2.5" holes with a hole saw in the thin plywood eaves/soffits. The fixtures look very clean installed. As there will be 25 x 3 watts of these, I decided to buy a 150 watt power supply from them for some headroom:
This is mounted in the attic and powered by an automated outlet so I can set on/off times and other triggers if I want. I am using 12 gauge landscape wire in the attic with landscape connectors to tap into the long wire without cutting and splicing at each light attachment. What's nice about the fixtures and not specifically stated or pictured at the vendor's site is that the "tail" wire is pretty long, I'm guessing around 4 feet, so it was relatively easy to grab the wire from the eave from within the attic without having to solder on a longer wire before installation. Plus it gave me a great reason to buy a Milwaukee fiber optic inspection scope to locate the wires from the attic
I bought 12 gauge wire to minimize voltage drop (12v DC power supply), and planned to limit runs to 100 feet without having a parallel voltage "reinforcing" run to keep the voltage up. I tested a fixture at around 200 feet of wire from the power supply and it was fine, so voltage drop or not, I just ran two big 500 foot loops to all needed areas and all the lights work fine.
Feel free to ask questions or offer up any other suggestions. Pics coming ...
Thanks ...
Thanks ...
