Multi-tube shop vac?
SpatialStage
Long Beach, CA
Has anyone seen or rigged a shop vac to have a setup similar to a central vacuum system like a home would have? My hope was to take a single shop vac, split it to 3 or 4 pipes that each run to a difference saw or sander. Each one could have a cap to keep the suction up for whatever pipe was open for use.
mikeburris
I do have such a setup. I got my parts at ACE and it is NOT a dust collection system. It is simply a shop vac setup. I am happy with it. It is for cleaning my work bench and vacuuming the floor. A small shop vac will not really work very well either.
JakeKohl
Greenville, SC
home depot does not carry pieces parts for these systems (which I've found frustrating).
Also watch for static electricity...dust moving through plastic tubes can charge things up leading to sparks leading to igniting dust leading to...
ringneck
Eastern Nebraska
I have used plastic and PVC in the past, but always run a bare copper wire through the pipe and attach it to ground, this helps control the static buildup.
coachrick
N. Austin, TX
WoodCraft and Rockler won't be the cheapest, but might have the connectors you seek. WoodCraft has a bit of a sale next week, I believe.
RickP
Annapolis, MD
This kit is a little bigger than a shop vac hose, but it might work:
HarborFreight Kit
SpatialStage
Long Beach, CA
This is a great tip, thanks!
Thanks everyone else for the suggestions and links. I'll be putting something together in a couple weeks and will post pics once it is complete.
Woody610nb
Concord, NC
Static electric build up is only a annoyance but not a safety concern. There is no indication that static sparks will start a dust fire. A shop vac will not move enough air to collect dust and chips effectively and will clog easily. Invest in a small dust collector designed for woodworking and you will be much happier.
zcar751
Knoxville, TN
Not trying to hijack the tread but if you uses PVC with any long runs you need to ground the tubes because there is a risk of fire. Usually this issue is on bigger systems but any sparks with dust is dangerous. Dust in general is dangerous and not only carries a fire hazard but in the correct situation explosion hazards. Probably not in a small shop but any large wood working shop or grain mills.
