Dead Blow
metaldad
nw indiana
I'm in the need (I think) of a dead blow sledge.
I checked HF's site, they only seem to have hammers.
Any input?
Jim Johnstone
Brantford, Ontario
If you arent afraid to spend some money find a lixie deadblow sledge. It will move the earth over a few thousandths when you hit it. We used them at one tool and die shop I worked at to align 20 ton castings on the mill.
I have a smaller hand held deadblow from them and it is scary how easy it will move things.
Sent from my SGH-I727R using Tapatalk 2
stonesfan68
Houston, TX
http://www.trustyhammers.com
Trusty Hammers makes dead blows for Snap-On, Armstrong, Estwing and several others. Their quality is excellent. You will get a better warranty by buying the hammers from one of the tool companies rather then buying directly from Trusty.
Trucky
Lixie, Nupla, Trusty Cook.
Any of those will do the task and then some.
metaldad
nw indiana
Wow, great selection, love the coo.
I don't think I could sneak in a $165 hammer in expenses.
metaldad
nw indiana
i need to install a flywheel on a quincy compressor.
facking thing is heavy.
depth of the bore is abouts 3''. diameter is about 40''.
i have tried to 'seperate' the hub with wedges......... but with it's construction, it's useless.
i have beaten in wedges far enough, to crack the flywheel.
regional rep says use a bfh. i really hate to wail on the shaft of an $11k compressor (my cost).
figure a dead blow would be less painful.
Ed ke6bnl
Agua Dulce, Calif.
I gave up on all plastic dead blows and built a lead dead blow and used it for a complete build of our Baja Bug and our next one and is ready for a melt down and rebuild. NOTHING BETTER IN MY OPINION
PT Doc
Is this a sheave with a bushing or a sheave for the exact shaft diameter?
metaleltr
Western Ohio
They don't make their own deadblows.
http://www.trustycook.com/
According to this Trusty Cook doesn't make them for Snap-On.
gatewaysysop
Arizona
I'm still a huge fan of Impact Poly Hammers for my needs. They've got just about every size you could ever want for. Not cheap, but there is no better dead blow hammer that money can buy, in my humble opinion. Here the link to the thread, and in particular my post with pics.
metaldad
nw indiana
flywheel is almost the same inside bore diameter, as the compressor shaft.
from this picture, which is kinda like the one I have, the 'spokes' of the wheel, where they 'land' on the center hub, kinda don't allow the bore to spread when putting wedges in the slots of the bore housing. I have cracked a few, beating in a wedge too far. I have installed a few, with wedges, and a 2x4 over the center, and smacking the living bejeezus out of it. Factory rep says that is the way to do it.
I do not like excessive force on a brand new piece of equipment, and this one i'm installing by myself. kinda hard to hold a 2x4 and smack it with a sheleliegh.
Rezeppa
Newport, MI
For your job at hand I would look into a large rawhide hammer. I am sure it will be just as effective if not more. Have you tried heat and an air hammer with a hammer bit. Also is there any way to get a puller on there with an air hammer and try to vibrate it off?
metaldad
nw indiana
I used to use a 2x4 and a bfh to pound the wheel off.
I was tired and sore earlier in the week.
Truck was 3 blocks away in lot.
I did the walk, and wheeled my pullers to the site.
I was able to use 2 jaws of my 3 jaw puller to yank it off.
Just rumbling thru my mind.
I'm going to try to fab a 'pusher' out of rod and steel, to get the wheel on.
no real flat place on the backside of the pump to 'land' steel, due to the oil pump.
Diesel Dan
TN
For little jobs :D like that we had two handled lead "knockers". They had a cast iron body with lead inserts on both ends and must have weighted 20-30 lbs. However, like you, I don't like hammering on something like that for fear of damaging the bearings.
Removal could have been done with a H-bar spreader and pulling it off. Installation should be done with heat to expand the flywheel hub and it will slide right on. Unfortunately I doubt you have access to a oven large enough to heat the whole flywheel.
What holds it in place?
set screws?
locking collar?
