spotco2
Had a 30x30 pad poured 4" thick inside my new pole barn Thursday. It does have fiber in it but no wire mesh or rebar.
When they started, they pulled a string across the floor and put in wooden stakes (about 1x2) every 4 feet at the height of the string.
When they finished it was so wavy that you could surf on it. Actually there is about 1/2" difference or so between the high and low spots. It was supposed to be flat. My Snap-On creeper will not roll across it without bottoming out if that helps with perspective.
There are several places where the wooden stakes are visible on the surface and several where the gravel is very visible, along with really rough screed and trowel marks and swirls. They were supposed to put poly under it also but forgot to. They also did not finish all the way to the top of the grade boards in several places by about 1/4"-1/2".
This was a subcontractor that my GC used for the concrete. The GC was furious when he saw it and especially the fact that they did not put the poly under it since he took it to them that morning so they could use it. They also forgot to bring a wheel barrow and had to use mine.
He is having them come back and grind it down, but my questions are how far can they grind it since the gravel is already at the surface in places and what about the wooden stakes that are showing through the surface? They were just 1x4's that they busted up with a hammer and were not treated wood.
If they grind it flat I know the gravel will be at the top in a lot of places and more of the wooden stakes are going to pop up.
I had planned on just sealing the floor, but can I do that with gravel on top? Would an epoxy coat work to cover all of the mess and give me a vapor barrier?
What about using a leveling compound to fill in the low spots and using epoxy on top of that?
What are my options on this? Is it fixable or does it sound like a replacement slab is in order? I'm worried that it's not thick enough in places and combined with the pizz pore finish job that it will crack.
I can not get a lot of pics because all of the metal for the building is laying on top of it right now.
