Unfinished Concrete Problem
FatFndr
oHIo
I am in the process of buying another house. It is perfect except for a portion of the garage floor which has been added on for storage. The owner poured the concrete (12 foot x 22 foot) and just left it to settle, unevenly, not floated nor troweled. In short it is a mess and rough walk on. I have been told by a contractor that it needs to come out and a whole new floor re-poured, concrete is about 3.5 yards and (with other fees) will run about $500.00. The whole job will be about $1500-2000 dollars.
I can't pour concrete but I can do a lot of other things. I saw a Post on here using the Diamabrush, that seems more for polishing and I need something that will not only take down the roughness but cut down some high and low areas.
Any ideas? Or should I just bite the bullet and have it torn out and replaced?
pauloman
happier and more simple to just pour new coat on top as suggested. make sure they put down a plastic barrier coat, no telling of the old floor had one.
F
FatFndr
oHIo
they make a self leveling concrete topping that may be worth a try!
That's what I was thinking until I just calculated that it would take 57.8 (59) bags of leveler @ 25.35/bag (Lowes) for a total of $1,470.30 just for the bags. That's pretty close to having it taken out and replaced which is probably the way I'll go. There seems no simple solution.
bobscogin
If you can get the old concrete removed and new concrete placed and finished for $1500-$2000, that's a bargain.
Bob
