Maxjax columns baseplate plans and dimensions wanted
Jvvmusme
Bogota, Colombia
Can anyone help me with the plans, blueprints or dimensions of the baseplate of the columns. A computer file or web link is greatly appreciated. I am moving my workshop and I am planning multiple locations and want to cut the baseplates with plasma and weld the anchors to rods as in the attachment.
Thanks,
Jose
J v v m u s m e at y a h o o dot c o m
Mr onetwo
Coastal Maine
Here you go...I got these directly from the factory.:thumbup:
  • MaxJax Base.pdf
  • maxjax template.pdf
skamp
Cypress, TX
I would not trust the diagrams. Several members have had baseplates that had different measurements (including mine). If you are looking for a general idea then this is fine. If you are making custom plates for mounting wait until you get your specific MaxJax before doing anything.
Steve
JakeKohl
Greenville, SC
Steve
Good point...I'm more interested in generalities for the future.
J
Jvvmusme
Bogota, Colombia
That s right. I have 2 factory blueprints with different measurements, specially in the distance between the 3/4 holes for the 5/8 screws. I had to measure my base plate and then proceed.
pmgriphone
Has anyone noticed a warp in the baseplates. Mine are not flat and warped toward the corners. They are off by at least 1/8" that seems a lot as I need to use at least two thick shims in certain anchor locations (which is 0.2in in thickness). Is this something to worry about?
nsogiba
Just wanted to bump this thread as I just ran into this issue. The first PDF is definitely incorrect, the hole spacing on my maxjax bases do not match that. The second PDF is correct.
Serj_DMR
Simi Valley, CA
Hey Guys,
I have attached the most recent baseplate layout for the MaxJax. Please feel free to PM me or call the main line if you guys have any further questions.
-Serj
Dannmar Tech Team
  • Base Plate 13 x 14.5 MaxJax.pdf
qu0vad1s
Hey Guys,
-Serj
Dannmar Tech Team
Reviving a 6YO thread. Are those baseplates still valid with the new version of the maxjax lifts?
