I live by water, full of air=full of water. I drain mine down after use unless I know I'm going to need it the next day.
Sorry, no logic at all to this statement. The only way water gets in the tank is by operating the compressor. You run it, water condenses in the tank. Bleeding off all of the pressure every day, and pumping the tank up from zero pressure introduces more moisture in the tank, than just leaving it sit, with pressure on it.
In deed, you should open the water drain and get all of the water out, which can be pretty frequently in moist climates, but depressurizing the tank each day makes no sense.
However, its your compressor and your electricity, do as you think best.
This discussion comes up about once a year. Put a good tank outlet ball valve on the compressor, and close it when you are not using it, and it should hold pressure till the next time.
I have a portable Sears compressor made in the early '70's that I bought new. It has a ball valve on the tank outlet and will hold pressure with no leakage what-so-ever for months at a time.
Charles
