land308
Hello I am looking for some guidance hooking up a used welder I purchased, up to this point I only had a small MIG setup but I got a chance to upgrade and purchased a DC-250 from a school auction. I have the manual and I am unsure what the superlag fuse translates into as far as the breaker size.
My service is 220 and I figured i would need a 100 amp breaker with #6 wire based on the table but i am not 100 % sure. i upsized to a 100 amp breaker because that is the size they had at the store and i figured it wouldn't matter. I believe I will also need a seperate means to disconnect the unit other than the breaker and that it should be sized at 100 amps also? This is going in a home shop
Thanks,
Rudy
Thanks,
Rudy
