Tool Pants
I have several click style torque wrenches, 5 of which are Utica.
One of the 5 is a Craftsman but it was made by Utica. I just bought the Craftsman/Utica for little money so I do not want to spend money on it or send it to a shop. It is the one closest to the black plastic Craftsman case. The one below that with the ratchet core out is a Utica. It is the same as the Craftsman, except the Craftsman has a slightly different ratchet head.
Both of these are about 25-30 years old. Both have the same issue. You twist the handle to set the torque. They go up to 150 foot pounds. There is a spring inside so it takes a bit more effort to twist the handle to get into the higher torque settings.
Problem is my hand alone is not strong enough to go past about 120 pounds on the Craftsman, and about 130 pounds on the Utica. I bought the coreless Utica when it was new and it was not like that back then. The other 3 Uticas are newer so I do not have this issue. I figure it is a lack of lubrication.
Any fancy way to lubricate them myself without taking it apart?
