I know this looks bad but is it really ...
workhurts
VA
So, while I figure out my garage lighting situation I decide to just get a Y socket splitter. While holding on to a couple of splitters it dawned on me that I could perhaps string a few of them together.
Now, I know what you are saying. Stupid. Right?
I plan on using 23W CFLs, so 4 would be less than 100W. Each of these things is rated to 660W and the original socket is rated to ???. I'm sure it's at least a 100W but that's probably more a heat related rating rather than a current carrying one.
So, with CFLs is this safe? $6 bucks gets me an equivalant of 400W (92W draw realy though). I have 2 light sockets plus garage door lights. So over 1,000 equivalent watts for next to nothing.
What say you?
Steevo
43.49600, -112.04300
I can't see the harm at 4x23w CFL bulbs.
If you start getting crazy and going with the high-wattage CFL's, you will over heat the splitters though, and have a potential fire hazard.
Are your edison bases plastic or ceramic?
I'd feel more comfortable knowing they were the ceramic ones.
Super Sport
West Michigan
Interesting idea! Looking forward to hearing responses, I might give it a go in my garage until I'm able to string up some T8s.
stratman977
Belle Vernon, PA
I did that in a garage I rented. It will work just find but the light doesn't spread all that well. Basically you have a really bright spot that you can't look at and then the rest of the area has a bunch of shadows. You are better off plugging a 4' cheapie tube fixture and plugging it into the socket.
W
workhurts
VA
I'm at a little over 12' on the ceiling so will give it a shot. Worst case, I'll go down two just using a single splitter for now or I could go and make a chandelier out of a dozen or so :D
Kevin C
Portland OR
I think your selling this idea way too short... If the socket is rated for a 120 watt bulb you could put sixteen, 7 watt CFL's in and still be under the current rating for the socket.
Think of what a great conversation piece it would be.
Once you get to 16 bulbs it's not hack... Its art. :rocker:
Time to hit the hardware store. :3gears:
I like the idea.
Silvercbr
Ankeny, Iowa
I put up 10 new fixtures this past weekend. Running seven 200W equivalent, only pull 42W each, but are a nice 2600 lumens. The other three lights only run 100W equivalent CFLs. The fixtures were only $30 each at Ikea. What a difference.
W
workhurts
VA
I like those 400W equiv bulbs. I just didn't see anything stronger than 100W equiv at HD.
The issue with the Ikea fixtures is that you really do need quite a few of them since you get almost zero light bouncing off the ceiling. As ugly as open CFLs are, they do light up a room when you have a nice white ceiling.
WRT playing with chords or climbing utility poles. Sounds like fun.
Now, how do I go about figuring out exactly what the original socket was rated to besides taking the thing down.
Off to find some different types of bulbs. Each splitter is aroundn $2.50, so that's $7.50 plus 3 bulbs to get 400W equiv. The single 400W equiv bulb looked to be about $10 from the previous post. Wonder what the bulb life ratings are.
Coolerman
Paint Lick, KY
Go to www.1000bulbs.com they carry a large array of CFL bulbs and have all the specs on them. They also have a great replacement policy. One the six 275W bulbs I ordered for my friends garage went bad after an hour of use. They replaced it no charge, and no questions asked.
NewShockerGuy
Northern Virginia / DC
a little ghetto looking but if it works it works...
I got this from amazon last year... put two of them up and the light was been great. Given this is only a temp solution until I start wiring florcent lighting in the ceiling.
http://www.amazon.com/gp/product/B004L8XC34/?tag=atomicindus08-20
http://ecx.images-amazon.com/images/I/21-kz1wyEqL.jpg[img]
[img]http://ecx.images-amazon.com/images/I/211nxy2JXlL.jpg
-Nigel
manioso
Princeton, NJ
I bought a number of Feit ESL40T/ECO (42w/200w equivalent) and have used them singly in my basement workshop very successfully. Lamps Plus had them on sale for less than $5 each, although they are usually about $10.
You might try using two of them in a single WYE adapter to get 400w equivalent.
68rustang
Cleveland, OH USA
You can also get them from HomeDepot.com for $8/ea shipped if you buy a case of 12.
