don
Argh...Your killing me with everything I want. Great work again on the new sign.
Your alternate use of the lift is exactly what I want to do with an in floor scissor lift.
ak
When you are old and the back complains whenever you bend over for any length of time you tend to find alternative ways to get things done.
The lift in the middle of the floor makes a great work bench that raises to the occasion and you can work 360 around it on a rolling chair. The blue lift next to the the one in the center makes a great secondary tool bench (catch all).
Get one they are a life saver.
Hey Don, the sandbox is looking sharp. Man, I cant even draw a circle much less cut one so perfectly like that.
Hey Jeff
Thanks man The blast cabin is coming along very well. I have the fresh air unit all set up, made a bracket to hold the air filter on the pressure pot yesterday. It is in the spray booth waiting for some color to be sprayed on it.
The only thing left to do is plumb the air filter to the compressor,shorten the air line that connects to my rubber suit and I'm in the blasting business (tomorrow)
Cutting the circle from a 6' square was a mystery to me, but my buddy Brett
(the guy sitting in the above picture) brought me a plasma circle cutter.
We attached it to the center of the square with a magnet that has a tab on it with a hole for a bolt. It has an adjustable rod that connects to the bolt in the magnet at one end and a circle that holds the plasma cutter on the other.
The cutting end also has a wheel that glides on the metal as you cut the circle, it worked slick
Good to hear from you Hope all is well at home.
Are you doing all the discs the same Don or have you got some other designs in mind for the other 3 mate. Look forward to seeing how they turn out as i have been making some repros as well and the cost factor is great and still has the wow factor. lee
Hi Lee
No I am not making all 4 discs the same
A friend is taking 2 of them and he is the guy making the pattern for the signal gas sign,and the other disc is a spare or back up for each of us
I ordered a 1 1/2" x 6' angle iron circle to go around the sign so it can be hung. When it's finished the sign will weigh over 125 lbs
Thanks for checking in guys
I will post more as the work progresses around here.
