Hi all! My name is Josh and I am currently in the latter stages (hopefully) of planning out the work to my new shop space. I've spent quite a lot of time researching here and am now at the point where I'd appreciate some input on my plan to upgrade the electrical capacity of my shop.
First, the shop itself. Its a stick built, ~20' x 30' building, on a slab. Has a newer roof, and for its age (thinking at least 20 years) its in great shape. A few things to address but otherwise a solid, dry structure. My plans include insulating, heat/AC and of course an electrical upgrade.
[/URL][/IMG]
The shop is currently fed power to a 60A box via an underground cable from the house, which is slightly concerning as there is no 60A breaker in the main panel. Currently the only current draw is a refrigerator and overhead lights. I plan to disconnect this at the main once I figure out which breaker is feeding it.
Moving on, I started by calculating my potential power needs and have decided that a 100 amp sub panel would be suitable. My "perfect storm" scenario would have me running a 15A dust collector, 15A pin router (220v), 21A heater, 15A air compressor (pin router has pneumatic head) and the overhead lights, fridge, radio (20A circut). Assuming I'm pulling max amps on everything, at once thats a healthy 86 amps
I'm not sure if I would ever pull all that at once, even with all that equipment running at once, but I figure for the sake of planning I should go ahead and plan for the "worst case" scenario.
With that number in mind, my plan as of now is as follows;
- 100 amp Sub Panel
- panel fed by 2-2-2-4 AL MHF, breakerd @ 90A at the main panel
I will dig a trench (straight shot) and am planning to run the entire length (about 50' shop to house) in conduit. I understand that the MHF is rated for direct bury, but I don't really see why a wouldn't enclose the whole thing seeing as I'll already be running conduit out of the ground at both ends. Thoughts on the contrary?
My understanding is that the MHF needs to be in conduit inside both the house and shop. Where I plan to enter the house I will have a 90 degree bend once inside the crawl space, roughly 10' of cable under the floor and then another 90 degrees up through the wall and into the main panel. Can I splice in some sort of SER cable once inside the house to avoid having to mess with conduit in the crawl space? Same for inside the shop? Would I want a junction box in the crawl space or outside the house?
Any advice on my questions, or overall critique of my plan would be greatly appreciated.
Thanks!
I'm not sure if I would ever pull all that at once, even with all that equipment running at once, but I figure for the sake of planning I should go ahead and plan for the "worst case" scenario.With that number in mind, my plan as of now is as follows;
- 100 amp Sub Panel
Thanks!
