Spannersphere
I'm looking at ratchets what's better sk round or Williams tear drop quick release or sealed. Hmm
The biggest down side to round heads for me are the facts that most styles cant be reversed with one finger like a lever on a tear drop and they're fat simply due to the nature of the design. Other than that its more or less personal preference.
which is better stihl or Husky?
Stihl all day long.
Sorry I could not help myself, proceed.
Stihl all day long.
The one that gets the job done...
Grasshopper I sent you a pm but let me review again for you in case you missed it:
Which is better Ford or Chevy?
which is better frosted flakes or corn flakes?
Start looking on CL and go to a few Garage sales and pick up a few used ratchets, just last week I bought a small metal green sk box for $5.00 dollars and it had 6 sockets and a sk ratchet so you should be able to pick up a few good ratchets on a small budget.
Then spend sometime and start using them, only then will you get a better feeling for the "The better one".
Remember ask 100 people and you will get 100 different answers...
I'm a pretty big fan of the SK round head ratchets. They're a basic design, but they're very strong and they have little back drag.
The quick-release Williams ratchets are made in Taiwan, if that matters to you. They're course tooth and identical to Blue Point ratchets. I don't like them very much, but I do like the 60-tooth Taiwanese Williams ratchets.
http://www.toolsdelivered.com/Willi...ols-3-8-Inch-Drive-Chrome-Ratchet-Drive-Tools
I don't like the Williams USA teardrop ratchets. They use a 36-tooth mechanism that was previously used in Snap-on 36 tooth ratchets. I've owned two new ones and they had so much back drag that I didn't like using them, so I sold them.
I like the round head Williams USA ratchets. I recently bought a 10" long 3/8" drive.
How often have you seen round head ratchets with the teeth in the head worn out? I've bought and sold many ratchets and I can't remember a single one I've had where the teeth in the head were too worn to work.
I have had some where the overall machining in the head is worn so the mechanism can move around a little, but they were very old.
In theory it could happen, but it seems more like a theoretical issue than something that happens in the real world very often.
Hmmm...
Again, I've bought many, many (in the hundreds) of ratchets. I've personally never seen one with broken teeth in the head. The broken teeth (and I've seen many) are always on the pawls, not the teeth in the head.
In the same vein, pearhead ratchets can wear where the gear rides in the ratchet handle allowing movement of the gear. That can't be fixed, either.
Again, I think you're getting into theoretical problems that aren't too common except on very old ratchets. Take care of your ratchet and either design will last many, many years.
A unique feature to round heads is a double pawl design. This allows for the strength of a 36 tooth ratchet to be combined with the connivence of a 72 tooth design. I don't think that that can be done with a tear drop design.
This is my favorite ratchet so far.
http://www.amazon.com/dp/B001HWCPFS/?tag=atomicindus08-20
Not all round heads have 2 pawls that engage at once and likewise coarse tooth ratchets are not inherently stronger. Its all about contact area and generally speaking fine tooth ratchets usually have more so usually coarse tooth ratchets are actually weaker.
Pardon my arrogance but it isn't friction that keeps the ratchet from slipping, it is the pawls teeth catching on the ratchets teeth (n the case of roundheads). If friction does not keep it from slipping then surface area doesn't matter, right.
... I don't know a single pro wrench that uses a round head as their go to ratchet.
