Yeah, I'm using insulated drivers, pliers, and nippers in residences wired for 110/220v. If you're implying that 1000v insulation is overkill, sure, but where does one find 220v-rated insulated tools? Only choices I've seen for Knipex are 1000v or no insulation rating.
Did I misunderstand the "rule" to use insulated tools when working on electrical circuits? If so, please school me. If Knipex insulated tools are wrong for the job, what should I be using?
Or is your point that I'm a limp-wristed girly-man for using insulated tools for puny 110v and 220v circuitry?
:supergay:
Do real men leave the breakers on and twist live wires with their testicles?
I'm so happy to see my sarcasm is having it's intended effect.
"Or is your point that I'm a limp-wristed girly-man for using insulated tools for puny 110v and 220v circuitry? "
You do mean DEENERGIZED puny and 220v circuitry, do you not?
"Do real men leave the breakers on and twist live wires with their testicles?"
Not that I'm aware of, anything I'm working on is shut down if it can be and if I cannot see the panel the breaker gets locked out.
"Did I misunderstand the "rule" to use insulated tools when working on electrical circuits? If so, please school me. If Knipex insulated tools are wrong for the job, what should I be using?"
It's a good idea to not use your 1000v insulated screwdrivers for work on deenergized circuits because you want those drivers to be in perfect shape for when they are needed to work on energized circuits. Anyone who has done electrical work with insulated screwdrivers can attest to the fact that the insulation gets damaged from regular use.
Now granted for the amount you will probably use them they'll last you your lifetime, the whole point was that you felt it necessary to make a comment about someone elses choice of tools that made no sense what so ever but you obviously don't enjoy your tool choices being questioned. Like I said, I don't care what you buy, it's your money.
Anyway, I'm done as arguing on the internet is like trying to teach a pig to sing.
