Anyone own these and can post some photos? Kind of curious about the quality. Note these are the newer pinned versions that they released in the last couple years not the older style with the joint that can be tightened with a screw.
Pic 1: Proto 3/8’’ dr. 10-19mm & Proto ¼’’ dr. 5-15mm sets
Pic 2: ¼’’ dr. 8mm (Craftsman on right, Proto on left)
Pic 3: ¼’’ dr. 14mm (Craftsman on right, Proto on left)
Pic 4: 3/8’’ dr. 14mm (Craftsman on right, Proto on left)
Pic 5: 3/8’’ dr. 17mm (Craftsman on right, Proto on left)
Pic 6: 3/8’’ dr. 17mm (Craftsman on right, Proto on left)
You got it all wrong. The Craftsman is on the left and the Proto is on the right.![]()
Apparently I don't know left from right....Yikes, that is embarrasing.
Thanks very much for the photos. Mind taking a couple more pictures, one of a couple Proto sockets looking top down into the socket themselves and then flipped over looking into the drive side?
http://www.sears.com/craftsman-42-p...p-00935750000P?prdNo=3&blockNo=3&blockType=G3
Not trying to persuade you, but these were unavaialable for a few months, just got an e-mail that they are now available. I just ordered these and praying to god USA. If they are USA worth everypenny. Aug 11th is Friends and Family so you qualify for 10% off also there is a coupon for $10 off a tool purchase of $100 or more.
I have the 6pt master set in 3/8 and 1/4 drive they use to sell. The quality leaves something to be desired. The plating is crummy and the pins have quite a bit of slop from the factory. You can actually see the spacing the pin has in the 14mm comparison that BB26s posted above. 100% better than nothing and fine for the weekend wrench but otherwise... eh...
I don't know if you could tell from the pictures, but the Proto's appear to have little splines all the way around the pin to bite in and provide just the right amount of resistance when swiveling.Strangely, the drive ends on the Cman are fine.
Except for those weird detents whatever they're called...
