Cryptic1911
We have a Jet jwts-10 table saw, that is about 30x40 or so, and it's just always in the way since all of our floor space along the outside walls is used.. it just sits in the middle of the garage taking up space. Ideally, I'd love to put it in the basement, but not having a bulkhead makes getting sheets of plywood down there basically impossible, so it's gotta stay upstairs. We don't use it a ton right now since most of the things we needed a table saw for are done
Has anyone seen a tablesaw hung from the ceiling before? We have plenty of height, so that would really be the only good place to store it as far as I'm concerned. It has the table extensions / wings, and these really long guide bars, so it's just a bit awkward. All that **** unbolts, but I'd assume it's a ***** to get it all aligned if you need to just cut one board
) just makes it a logistical nightmare.. plus the fact that it has a short narrow stairway with a 90deg turn at the bottom would make it impossible to get a sheet of plywood down there unless we cut it all up outside first
