Working on a dark work bench?
BellyUpFish
Alabama
Thinking about staining the bench top of my recent workbench build, but I'm not sure about working on a dark bench. I kinda like the lighter/brighter color top..
Anyone with .02?
Wood'nMetal
PNW Oregon
Gotta agree with jay8s, go bright or go home. Even bare metal can be hard to find screws on. Nothing wrong with a nice bright white or light grey.
Dale Leeds
Williamsburg
Paint it whatever color you want. Anything can be hard to find on any color as far as I am concerned. If you drop something white- it's going to be hard to find on a top that is white. Correct. Just put in a couple of flood lights or flouresant lights overhead and you shouldn't have any problems.
wesalexleft
Memphis, TN
Covered one of mine with some Formica. A 4' x 8' sheet doesn't cost much. I can write on it, marks for length, etc. and it washes off when I'm done. This isn't so much a pounding bench though, just a spot to work at for smaller projects like carbs, assembly, and the like. I used an almond color.
steve308
Painted my counter top gloss black and I use a couple of cutting boards painted red or yellow to work on and have the wall equipped with magnetic tool holders. Keeps me from spreading sh*t all over the place and I don't worry about damage to the tops with the cutting boards. The black looks great against the white walls and red and yellow cabinets.
kbs2244
Mine is white.
Cheap seconds (bent corners) of the cheapest bathroom siding from the local big box.
Two or three dollars for a 4x8 sheet.
Stands up to everything except acetone and three years of use.
Then it gets replaced.
I could never find anything on a black surface.
Sometimes function has to trump style.
Jack Olsen
Los Angeles
I went from light to dark on two of my big benches. I never noticed the change. So long as your workspace is well-lit, I think you're fine.
I don't think the same is true for a floor, however.
zoomzoomjeff
Des Moines, IA area
Mine is a 4x8 sheet of white formica type MDF. I would never switch to anything else. Yeah, it shows some scratches, but it also reflects light from around the room to make it a nice area to see on. Plus, I usually write notes on it with my carpenter pencil throughout various projects and just brake clean it when I'm done.
Responder
Saskatoon, SK
How is it holding up after using brake cleaner on formica?
nehog
Jaffrey, NH
Most of my benches are covered with floor tiles (white with gray flecks or splotches) and things show up well on them. The white is now dirty, which helps.
