tkmitchell
I am looking for my first drill press and came across an this old delta. Trying to find more information about it to determine what is a reasonable price to offer.
Looks in good condition. Runs good. No obvious bad sounds. Couldn't check runout, but did not see any visible bit wobble.
Appears to have over 5 inches of quill travel.
Floor standing model. Didn't measure distance to bit, so not sure of size.
Could not find model number.
Serial number is 108-4982 which i believe indicates built in 1953.
Label says made in Milwaukee, which means 1952 or earlier.
Has a 1hp dual voltage motor and it is currently set up for 110.
1725 rpm on motor label.
Any obvious parts I should consider replacing, or just take it down and clean it good?
It has two sets of pulleys with 5 sizes on each one. How do you determine how many speeds it has? Or what they may be.
Supposedly original stuff. Told it was bought new by this guys relative and used in a shop. While old and has been used, it has been taken care of since I was able to turn it on and test it.
Really newbie questions, so I would appreciate any information. Don't typically buy used stuff, cause I don't want to spend my time fixing the tools. But in this case, this particular tool (drill press) for some reason I am drawn to one of these older devices.
Seems like while older and without bells/whistles, they are still better than what you
can get for the same money new.
For people looking for this older stuff here is something else I have an eye on. Seems really interesting.
http://irsauctions.com/popups/bidde...ction=DIS8QOOKWU8X3T6U8WK3MOPFFUMPTC&id=17274
I can't imagine what a production table for a 17" weighs. The production table on my rockwell 15" is one heavy SOB, I can't imagine a 17" version.
I wonder what pulley set the machine in question has? Typically the production tables were equipped with the slower speed pulleys and MT2 spindle, but with the JT33 and production table I wonder if it has the high or low speed set.
Not to mention that the drill press is actually a Walker Turner and not a Rockwell/Delta. I like the "comparable one will cost $500" will that come with rust and damaged belt cover as well?
Machine sellers that know nothing about machines
