glue
BADSIX
oregon coast
I have built some shelves in my yard barn where I store all my out door stuff along with a tractor and lawn care tools. And I want to use some of the plastic Folgers coffee containers to store assorted wood screws nails and other fasteners. I would like to glue the item that's going to be in the container to the out side so I can see what's in each container. Anyone know what kind of glue would stick well to the plastic containers?
Thanks Jay D
G_P
Central CT
Rough up the plastic with sandpaper and attach the item with JB weld.
Personally I would just drill a hole on either side of the hardware piece and ziptie it on.
Sent via carrier pigeon.
Gerald O
NC
If those containers are polyethylene, as I suspect, no type of glue will hold.
Take a picture of the item, print it on label paper, and stick the label on.
nehog
Jaffrey, NH
A strip of clear packaging tape, all the way around (as it won't stick well to most plastics).
theoldwizard1
SE MI
Punch two little holes and then use any kind of thin tie wire.
Stainless steel safety wire with heat shrink tubing makes the best tie wire you can find. I know the heat shrink tube is overkill, but it is great if you have an application where toy occasionally need to until and the re-twist the wire.
G_P
Central CT
If it gets hot where you are the hotmelt glue will get soft and gooey during summer.
It also tends to fall off in the winter when cold makes things shrink.
NUTTSGT
Northern Central Ohio
You could drill two small holes (1/16-3/32") and use some Clear silicone RTV. Just make sure that is goes through the holes and mushroom it over on the backside. Once it dries, the RTV won't come off of the plastic can.
BADSIX
oregon coast
thanks, another good idea. i'm thinking that this or the tie wraps will probably work the best. I personally don't think anything is going to stick to the containers very good. I may try the hot glue and see what happens.
G_P
Central CT
Hot melt glue is for craft projects and temporary stuff. No way will it hold metal to a plastic can for very long.
BADSIX
oregon coast
well if anyone is interested in doing this I found a glue that sticks quite tight. you can peel it off but it takes some real effort. its called AMAZING GOOP OR WWW.AMAZINGGOOP.COM my tube says marine on it
thanks for all the input on this. Jay D
Jere
Is that goop a name brand of contact cement by any chance or is it some other kind of stuff.
RickP
Annapolis, MD
It's a name brand:
They have a whole line of different specialty glues. I remember using "Shoe Goop" 30 years ago.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I'm with NUTTS....Clear silicone caulk.
Years ago I read in a magazine like Family Handyman about using clear silicone caulk on the pegboard hooks to keep them from lifting out. It comes in handy for more than just caulking.
