Installing a new lift, different mounting holes
Dr.HairyOlds
New to Nashville, TN
Hi there,
I have a new (to me) lift that I want to install in the same location of my old one. The pad bolt patterns are obviously different so what is the safe way to do this? Do i just cut the existing bolts flush to the floor and put in new ones? I know the lift instructions talk about no cracks or seams within a certain distance but I find it hard to believe that garages pour a new pad every time they swap a lift. Help! Thanks.
tomsmith
Might be a good idea to cut out a 3x3 or 4x4 section of the concrete and have that repoured?
D
Dr.HairyOlds
Tom, unfortunately, needs to be a lot more concrete to go that route. Otherwise it will pull the new section right out of the old.
Fleixa_ got any more details on the epoxy or where to get it?
sberry, that would be great if it'll work
Has anyone done this themselves before?
oilslick
Central illinois
Right or wrong I just did this at work . The new lift is just shifted over a few inches to put a little distance between old and new holes. Both of our were forward brand with ten years between them, holy **** they have cheapened them up. The new one is a flimsy ************* compared to old one.
avc8130
Mohawk instruction manual says no closer than 6" to any concrete disturbance. I have to assume that holes would fall within that category.
ac
avc8130
AVC, that is great! Going from an old weaver narrow bay to a Mohawk 9k lb. The new holes will definitely be away from the old ones.
A System 1A? I just finished drilling holes and standing up mine this evening. Tomorrow I am going to tackle assembly and hopefully running the hydraulic lines. I need to take ~12" out of the vertical hydraulic lines. I'm not sure how I am going to reflare them...
ac
avc8130
With the Mohawk it wont be an issue.
Interestingly enough I was at a shop this morning where they pulled out a 30 year old cable lift to install a 20 year old Mohawk.
They placed the Mohawk right over the old spot and just drilled new holes.
:dunno:
