brianstrange
- Joined
- Mar 24, 2013
- Messages
- 18
I'm Building a detached garage, and would like to add a second sub panel (garage) to my service, and need some advice.
Here's what I have (existing):
200 amp service with a small Wadsworth panel.
100 amp breaker feeding a small GE sub panel (4 of 6 breaker spots occupied) This is right net to the main panel.
Grounds and neutrals are shared on both panels
Existing sub panel was fed with two hots and and one heavy ground and neutral wire buss
Here's what I want to add:
I want to send a 50 amp circuit to the detached garage (2nd sub panel).
My preference would be to use a cable that can be used in the house, and directly buried for ease of installation.
If a GFCI breaker is required to feed the 2nd sub panel, I will need to send power from the existing GE sub panel (lack of Wadsworth products)
I do not want to get into replacing the main panel at this time.
I see that there may be an issue with both existing panels sharing grounds
Can someone give me some guidance? The existing work / panels are from the late 70's. I want to do this right, with what I have to work with.
Thanks in advance,
Brian
Thanks in advance,
Brian
