Menards has a filter reg combo that is 1/2, it comes with oiler but you could throw that away. This has 2 extra hydrants not needed. One is hi pressure and one regulated, it should be removed and plugged but no one uses it as the reel does the work. In this location the one reg feeds drop[s to the hoist, a feed to the paint booth and the reel.
Its easy to get carried away, in hindsight I could easily or near as easily simplified my system, we were not really sure exactly what was going to happen.
That is the beauty of a simple 1/2 system in a small shop. I have seen some under plumbed because of no effort, a few with 90% of the fittings never used but a couple spare fittings and ******* and a guy can change or add as needed, maybe even re think the whole thing, parts are cheap. A great selection of ready made ******* under a dollar.
I do NOT like hydrants and sections of hose for plug/unplug. I have fixed whips with a coupler at the tool or a reel. As I mentioned, those could be removed but the place is generally well supervised and you just don't need to get creative on most days, its already in place. I have a few things semi fixed, a plasma and 1 hose coupler connected at another location. I would just as soon use a barb and a clamp and I try not to leave tools connected, most parasitic leaks come from couplers.
Some of these pics are old,, many as we did them. The changes are fewer and minor but we didn't leave some awkward setup just because "that's the way it was" I will move a pipe if there is a reason.
I guess I do have 2 overhead I should check for leaks, they were drops folr hoist and a ready made 25 ft was perfect, it made a plug and play setup but I really copuld and should remove the connectors and screw direct.
