heating a shop
heinalanka
I am new to this forum and was wondering if anyone has recommondations for infrared tube size for my shop. it is 40 x 60 with 16ft hight. 3 doors on one side 10 x 12 wanting to run 1 heater 50ft . what size? or should I be running 2 heaters let me know what you guys think.
98ssuck
British columbia
Calculate the heat loss of your shop. Every thing you calculate must be based to give enough heat to overcome this. The tubing size, number of loops, loop layout and boiler sizing are all based off your heat loss.
H
heinalanka
I also for got to mension I live in northern Ontario where winters get to -40 and we fix vehicals so there are frozen vehicals in the winter months coming in for repair.
Charles (in GA)
50 mi south of Atlanta
I think he is referring to a overhead gas infrared system and not floor heat.
Charles
jonzer12
be sure to make sure you get full coverage of the floor as well. There is more to tube heaters than just matching up the output to the heat loss, ideally you want the configuration to "paint" the entire building in heat, not just throw lots of heat at a certain area.
I am 6 months in with my tube heater and I am very glad I went this route over forced air, there is no comparison.
H
heinalanka
the walls are r 21 and the ceiling is r40 metal lined, this is a automotive shop, I was wondering if I need 1 40-50 ft heater or 2 of them one at the front of the shop and one bellow the doors . will radiant tube heaters heat 40ft away from the front wall on a 45 deg angle.
jameswood
Nebraska
My 50' center-dual fire at 45 deg heats fine across that distance.
