Air Compressor Info Please.
What is the difference between the stock pressure switch 'CW210100SJ' (around $40) for my 5hp 20 gallon compressor and a cheap universal 4 port switch ($15-$20)?
Can I swap my 20 gallon tank for a bigger tank?
Thanks,
Ian S.
Thanks,
Ian S.
You could swap the tank for a larger one, just have to be careful on how large of a tank you are talking. You will get into the duty cycle of the pump/motor. If it runs for too long of a time it can overheat the pump/motor. Usually pumps and tanks are kinda a matched item. Ex. you won't see a tiny pump on a large tank (long run time) nor will you see a large pump on a tiny tank (pump won't get up to temp). Of course there are exceptions to those, primarily the latter (ex. portable compressors).
