just a quick wiring question
chadsy
I had a couple of fixtures that recently crapped out on me. I have two spaces like the attached pictures indicates that are both wired to the same switch.
Would I be able to install a couple of outlets on these and then plug in fluorescent lights and run them this way?
Thanks in advance for any comments and advice! I've been learning a lot from my short time in this site.
jlmotox
SoCal
Yes you can wire an outlet or a fixture, the only problem you might run into is the box in the ceiling is different for fixtures and outlets...nothing you can't swap out just a little more work is all. Looks like 14-2 Romex wire you have there now so 15amp outlet would be the one you want, but check local elec code to be sure some may say 20amp is ok...
66dave
Boise!
Yep, black wires are live (gold color screws on the receptical), white are neutral (silver color screws on the receptical), bare is ground (bottom green color screw on the receptical). I would remove that box and put in a old work receptical box.
Charles (in GA)
50 mi south of Atlanta
Most of you folks make me wonder. Everyone is suggesting swapping out the box, which is a major hassle. It might not even be possible if the OP doesn't have access to above it. All he needs to do is find a round box cover that accepts a duplex receptacle, and connect it up. You can even buy the cover with the receptacle already mounted in it.
Why suggest ways that are so difficult when there are easy and simple ways to solve it?
Charles
C
chadsy
Charles
Thanks, Charles. This is exactly what I was thinking about.
Yes you can, but if this is in a garage they must be GFI protected. This can be done several ways.
This is indeed in my garage. I will do some research into getting them GFI protected.
15 amp it is!
Zeke
If all you're going to do is use those for light fixtures, maybe direct or hard wire the fixtures to the boxes with the right connections (no cords).
I think 2 things are in your favor here by doing that, but I'm not the code police.
1. You won't need GFCI
2. You are grandfathered to what the house had when built assuming it is as new as it looks.
Jim B
California, USA
Do you need a box in the ceiling or can you just install a clamp/bushing thingy in the light fixture and run the romex directly into the light fixture?
wyliesdiesels
Modesto, CA
You cannot put a 20a outlet on a 15a circuit!
98ssuck
British columbia
Why not put a bottomless octanginal box on the existing box and the. Run conduit or Bx to a fluorescent light. IMO that would look nice than a receptacle on your ceiling.
