Help sizing a garage for lift
derekeh
I'm looking to start on a garage but haven't decided on my dimensions yet. I want to add a 2 post lift down the road so I want to have enough room for that. My worst case scenario would be a long bed extra cab pickup. I've never used a two post lift so I'm not sure how far to install it from the garage door. And then how much space is needed in front of the lift.
To allow room to work on two cars, im thinking 30 or 32 wide and 36 to 40 deep. Any help would be appreciated. Thanks.
Aahz
Chicago, IL
I wouldn't design a new garage around a lift, but I can give you some ideas of what a lift bay requires. Each lift manufacturer is different, but the principal is pretty universal.
A shop's work bay should be approximately 12' wide x 28" long for standard automotive work. If the lift is asymmetric (10K capacity or lower), it should be installed 9-10' from the nearest obstruction to the front (ie. wall, toolbox, workbench, etc) and centered in the bay. If the lift is symmetric, you want to move it back to 11 or 12' from the nearest obstruction. Since you will want room to walk around the lift, it should be at least 2' from the nearest wall on either side.
Ceiling height is the biggest issue with personal garages and lifts. For a 2-post lift with an overhead cross beam (most popular), you need a minimum of 12' clear. Keep in mind that many folks have made the mistake of putting in 12' ceilings and 10' doors. The garage door opener, unless installed high, will hang down into your lifting space. Having the garage door angle up to run along the joists saves a lot of headaches.
Congrats on the new garage! If I can be of any help, feel free to let me know!
J Persons
Louisiana
Most Bendpak two post lifts require 145" clearance. Not thinking, I made my ceiling 12' That is 144". I will now have to use a floor plate model or another brand that doesn't require 145". I have two 10' roll up doors, and spaced them 4' apart and 4' from the side of the building.This will allow for the lift post and will still allow me to walk between the lift and the side wall. My shop is 32'X48' and I have plenty of working room in the front, even when my F150 SCab is in the shop.
hanly2
Maybe you could help me out here. I am building a 24x32 and I will have the door on the 24' side I was trying to decide between a 18x8 or 9 or 10. I want to put a shelf in the back part of the garage 4-8' deep. This would give me 24-28' from the front to the shelf. Would I be able to put the lift in still? I probably wont be able to lift a car with the door open right? How do you have the door installed along the joists?
Thanks.
Cobra6
Tennessee
Thanks.
Do not put an 8' wide door on your garage - I have a neighbor who did that and he has to fold his mirrors in on his full size truck to get it in and out of the shop. He forgot to fold them back once and his wife took the mirror off and messed up the wall.
You can do an incline lift - it is a custom rail made to your roof pitch - it is not too bad to do - you just have to change your rail angle from horizontal and change the spring tension -here is a picture of mine -
hanly2
Its 18. And that door setup is awesome but my trusses go the other way
Cobra6
Tennessee
If your trusses run the other way, an 18' wide door may not give you much height for a lift - have you considered more than one door with them both being high bay lifts?
I would have to see pics or a layout to really guess at it
My ceiling is about 15' high in the center
hanly2
How far are your posts mounted from the door? Looks like you have the same flooring I bought is it versa roll?
