Craftsman screwdriver/socket
mudflap
cincinnati,ohio
Maybe im the only one who didnt already know this, but just in case i thought i should post it....Craftsman screwdriver handles were designed to fit perfectly and grab inside a 15/16 socket...One of the new whippersnappers at the shop showed me this last week......Old dog new tricks....:dunno:
ChevyEFI
Phoenix, AZ
I wish this were more commonly included.
I second that! I was just thinking earlier tonight it'd be nice if Snap On ratcheting screwdrivers had the female drive end instead of the cap with the bits, though I guess it would be too much ratcheting going on. Would make sense on the regular screwdrivers.
Biomed
Minnesota
While this is an interesting tip, aren't there better tools available like this (from Snap-on and a myriad of other vendors):
or this (from Snap-on):
or even this (from McMaster):
where you have less chance of damaging your work, tool(s) or even yourself?
ChevyEFI
Phoenix, AZ
You must be in the midst of some heavy safety training to come up with that kind of context to talk about these kinds of tools. :dunno: It's just another way of using the driver handle, and not a high-risk one particularly.
Biomed
Minnesota
You must be in the midst of some heavy safety training to come up with that kind of context to talk about these kinds of tools. :dunno: It's just another way of ABusing the driver handle, and not a high-risk one particularly.
I fixed it for you. :D
I guess I don't have such a problem with the socket on the screwdriver handle but I sure wouldn't want to mangle my screwdriver handles with a pliers or adjustable wrench. What YOU do with YOUR tools (or vision) is not my concern.
I expressed my opinion and you listened. Now you expressed your opinion and I listened. I hope this is over.
cburnscrx
Indianapolis
Um...of course there may be better tools, but a set of Craftsman screwdrivers probably cost less than the snap on bit. You must have a lot more money than I do...
Spudland_Dave
Maine
Can't do that with a Snappy !!! :bounce:
No you cant. The Hex Bolster on a MAC/Snappy/Whia/etc screwdrivers are far superior.
All I see with that truick is an easy way to strip the shank right out of the handle, after all the shanks have relatively small "Wings" are only pressed into plastic.
I've got a Craftsman nut-driver with the 1/4" female recess in the handle, one time when I applied a little extra torque with my 1/4" Ratchet, I heard the handle cracking...tells me there isn't a solid shank under the handle.
The MAC "Handled" extensions are exactly that, a full length, one piece extension with a handle on them.
djb2
Redwood forests
If you ever find a Craftsman driver with a chunk missing, you'll know how it happened.
I've always used a wrench. A deep socket is a much better idea, since it spreads the load.
The Craftsman Professional line has hex bolsters on the top of the metal shaft.
TwoInch
NW INDIANA
If only they were made with harder tips!
i have had pretty damn good success with a regular blow torch, and giving them an oil quench.
makes them plenty hard, and i havent had a single one turn out too brittle yet. took me about ten minutes to do 8 or 10 drivers.
i have no issues with craftsman acetate screwdrivers. use pretty regularly, but i do own and use Cman pro, and other better quality drivers too.
Jim C.
Hmmm... Good tip I guess. I never considered it. I can't think of a time that I've needed to try something like that to remove a fastener, but it certainly doesn't hurt to know. Still, if I needed to add a little extra torque, I think I'd be more likely to use a spinner manufactured with a female socket on the end (like those depicted above) versus slipping a socket over the handle of the screwdriver, spinner, etc. Even though the socket method seems like it would work without causing too much if any damage to the driver/spinner handle, I think I'd try other methods of work before resorting to a socket and driver/spinner handle union.
Jim C.
CNGsaves
KS and OK
Agree. The SnapOn handles are tougher by design and might do the job without any extra assistance anyway. Of course, we know the SO tips will hold up.
Overdoing this trick with a CMan cheapie screwdriver is surefire way to break the plastic loose from the shank. Thus abused tool beyond it's capability = throw away.
The better screwdrivers with integrated nut where the shank goes into handle would likely be more useful anyway with an open-end wrench.
I generally find the ole ScrewBall for real stubborn screws. Put your weight into it, and can generate some good torque !! ;)
shocksandstrutz
Wentzville, MO
cool tip, i never knew that, thanks for posting, ill keep that in mind if i ever run into a situation.....although i have a manual impact screwdriver for those hard to loosen screws
diggerrick
Good tip for when you need a little more torque, but when you need a lot more I use insert bits or:
sorry about the size - when did HF make these so large?
zkling
Interesting concept. I'm not sure if this was a design thing or a concsidence. I quickly browsed through a few old catalogs and could not find mention of this "feature". :dunno: I like my older, all black, cman pro screwdrivers. They have hex and square shafts the entire shaft length. So you can put a wrench on it if needed.
:+1: When I custom grind bits for gun and knife screws, I usually harden them this way if the steel seems too soft. Or if I get a bit overzealous while grinding and take the hardness out.
