moparfreak
So I'm rebuilding a transmission and have a few threads to repair in the case. I need a 1/4-20, 5/16-18, and 7/16-14 helicoil kit to put in new threads.
I went to the auto parts store and each of the kits were 20 bucks...all they had was one tap, a few of the thread inserts, and a cheap plastic tool to screw in the inserts.
Is there a way to just buy the thread inserts and plastic tools separately? Are the taps they use specific for those inserts, or are they standard taps that you would find in any tap set(which i own).
I just don't want to spend 60 bucks to repair a few threads.
Thanks,
Adam
Thanks,
Adam
- I have also made a helicoil removal tool (only works when the tang is still installed). I simply made the inverse of the installation tool so that it would grip the tang and allow removal of the heli-coil should you have failed to drill or tap a blind hole to the proper depth.
