unusual ratchet clicks
andre_saltiva
I'm just bought jonnesway ratchet fine tooth a couple months ago.
The problem is i can hear the clicking mechanism about 1-3 clicks when i'm using it to tightening a bolt/nuts sometime
And the handle just slide forward a little bit.seems like the teeth is loosing their grip for a while.but everything came back to normal after that "1-3 clicks". It's work normal but just annoying
It is normal?or a sign that is gonna be brake soon or later?
What do you think?
[/URL][/IMG]
[/URL][/IMG]
i think the problem is here as you can see on the red mark teeth
[/URL][/IMG]
am i right?
Fedwrench
Valley of the sun
Yeah, i think so
But if some teeth has been broken, why does is not happening every time :headscrat
Just guessing without seeing a picture of the ratchet but, the issue could be on the drive gear and you only notice it when that area is engaged by the pawl gear. Again, no way of knowing without looking inside.
I'm unfamiliar with Jonnesway tools but, when say sealed, there isn't a split ring, snap ring or screws to remove to disassemble the head??
rumb
Latvia
If it's sealed like Facom Sealed pear JL.161 - there is no way to disassemble it! :///
A
andre_saltiva
finally i can open it and see what is the main problem
[/URL][/IMG]
on the red line some of teeth is dull
i think this is the problem, do you agree ?
