Edwards school bell....how the hell do you wire it???
toomanytoyzz
Malvern, PA
I picked this Edwards 55 series bell up yesterday at an auction and always wanted one for the garage to hook up to the phone or the door bell. I opened it up, but couldn't figure out how you hardwire it. Oh yeah, almost forgot, I'm Brian and I'm a ***** in the electrical department :lol_hitti.
WWIIjeep
Arizona
The wires go to the two threaded shiny things in your middle photo. The screws are missing. They'll be either 6-32 or 8-32 thread pan head machine screws.
But--and this is very important--first you need to get an 8-10V bell transformer (120V in, 8-10V out) or you'll fry the bell the first time you use it.
Thumper68
Duluth MN
I used 2 of those as a motion alarm in my first shop, took a old motion detector from a out door light wired it to a transformer and then to the bells, when someone would walk in the man door the bells would go off. since it was a carrige house and my apt was upstairs I would hear the bell and I could go investigate.
It was also nice when I was working on the far side of a vehicle, no one could sneak up on me.
110 to the transformer, one line out to the switch and then to bell, 2nd line straight to bell.
T
toomanytoyzz
Malvern, PA
Thank you:thumbup:!! That would have really sucked:shocking:.
jeffmoss26
Cleveland, Ohio
What the others have said. Don't know if it would work for a phone; a normal line sees 90 VAC when ringing. I've got a RadioShack dual bell ringer that's specifically designed as a phone ringer.
NO!
Its a low voltage unit and its printed RIGHT ON IT!
What WWII Jeep said, or you can also use a 6V Battery safely.
Wont work for a phone unless you use a relay to run the low voltage the bell needs...
T
toomanytoyzz
Malvern, PA
Are the transformers expensive? I might use the 6V battery option. I'm trying to do it as cheap as possible.
I really appreciate the help!!:beer:
While a 6V wall wart would have the correct voltage, I seriously doubt is would have the Amps required. I'd guess that this bell takes WELL over an amp, and very few WW are over even 1 amp most and a tiny fraction of that usually .3-.5 (300 - 500 ma (Milliamps)
T
toomanytoyzz
Malvern, PA
Well I found one on ebay for $8 with free shipping. I googled the model # of the bell and edward's recommends this model of transformer to be used with that model bell.
So, I guess I need a button, some wire and the two correct screws to get this going? Does the transformer get wired and stored in the back of the bell, or does it sit in-line somewhere between the button and the bell?
Typically the transformer gets mounted to the side of an electrical box, and low voltage wire is run to the bell.
This^^^ you want the 120 to be out of the weather, and the button that rings it is low voltage side only to run the bell. This is to keep the 120 shock hazard low...
OK, Never mind, I've been reading "VA wrong for years... (WTF is wrong with calling watts W"?)
MikeF2316
Thornhill, ON
Because Watts don't always equal Volt-Amps. With inductive loads (transformers are inductive loads) the current peaks happen after the voltage peaks, not in step as with a pure resistive load. Wattage is calculated by multiplying voltage and current happening at the same instant. VA is calculated by multiplying the peaks, which will give a higher number.
Look at the rating of any UPS - the "VA" number is always then one quoted and is quite a bit larger than the "W" number.
Example:
http://www.tripplite.com/en/products/model.cfm?txtModelID=3196
The model number and VA rating are both 1000, but you can see on the specifications tab, it's only rated at 700W.
