Vtown76
Hi, first post. Been lurking here for ideas as we add on to our house.
We are putting a 24x30 addition on the end of our existing raised ranch. Garage down, master suite up.
I am maintaining the original 2 car garage (work shop) and of course adding 2 more bays. (all insulated)
The heat and domestic water for the master suite is being routed through the exisiting garage and as such the space will need to be protected from freezing or else gycol will need to be added to the boiler. Not sure why the contractor isn't worried about the domestic water freezing if unheated space but....
Don't matter i guess, I want heat in the garage anyway.
Quote to install 2 Hot Dog hydronic (one 30 and one 45) is $3100. Seems like a lot of money. Google tells me the heaters cost just under $1000 each. Is $1100fair for install and misc parts?
Buddy of mine says install a couple electric heaters, they are like 300-500 each. Of course the sub panel is already in (90 amp). Not sure I should consume more than half of that for garage heaters?
There is no gas here.
Is there an cheaper alternative to the $3100 hydronic package?
Is electric less efficient than using the hot water from the boiler?
Other ideas?
Thanks
Other ideas?
Thanks
