Flatland Dave
Wiring in the shop. Running 12/3 romex to GFCI receptacles. Two receptacles per box, on separate circuits. Do I run jumper wires off the correct neutral to the correct terminal? or?
Wiring in the shop. Running 12/3 romex to GFCI receptacles. Two receptacles per box, on separate circuits. Do I run jumper wires off the correct neutral to the correct terminal? or?![]()
Neutral can be shared bwtween the GFCIs on the line side but NOT on the load side. This means you will HAVE to run two 12/2 Romex cables from the GFCIs to each and every outlet downstream!
Planning on GFCI's being the first receptacle on each run.
Looks like i'll be running 12/2 downstream.
Thanks
Have thought about that.GFCI breaker is an option
Yep, thanksmake sure to install a 2 pole breaker if using 12-3 to the first recepts.
