Canopy for Paint Booth
Thumper68
Duluth MN
Yup! I don't use the covering that comes with the tent, I use 6 mil poly that way I can use the nice white tent for other things.
Use a tarp or 6 mil poly on the ground, Make sure to cut a hole in one side and tape in a good furnace filter and put a low pressure fan on the other to draw air through.
NHBandit
East Tennessee
Painting a car outdoors ? In CA ? Won't the EPA lock you up for life ? Aside from that I think it's a great idea. :thumbup:
PCO6
Newmarket, Ontario
For car parts (vs. a complete car) I've used an Easy-Up canopy with 6 mil poly for 3 walls and one side left open. It wasn't fancy but it worked.
EDIT: I should have added that I've also sandblasted using the same set up.
Vegaman_Dan
Pacific, WA
I plan to do this myself as it's an easy sealed and controlled environment. Plus if you're doing it in day light, you'll get a lot of light inside from the sun hitting the white vinyl and causing the area to glow bright.
Positive pressure is the key- you'll never seal that thing from debris getting in, but if you blow filtered are into it and give it some options to get out, it should keep bugs, debris, etc from coming in.
Don't forget a man door!
DpSyChO
Blue Ridge Mountains of Southern Virginia
I've heard of it done as others have noted with clear poly for the "walls". Also used a pc of AC trunk line (ductwork) going under the car (to the middle) then outside the canopy with fan rigged up to the end to help create a semi functional down draft effect. Ideal... no..... helps... yes.
MP&C
Leonardtown, MD
What's the next size up? My Devilbiss spray booth is 24 x 14 inside, and many times it has been cramped for space...
PCO6
Newmarket, Ontario
The canopy I referred to in post #4 above is only 10'x10'. Obviously I can't paint a car in it but it's great for most parts.
IONH
Central Massachusetts
Positive pressure is a good idea if you've got grass under the bottom sheet (whatever material).
I would try to do it in on a driveway though, just to lessen the chances of bugs making their way through.
While I have a garage large enough to paint a car in (2x2 with no posts), I like this idea because my compressor can kick on without throwing a bunch of air around from its fan.
79firebird
Victoria bc
Yup they work fine i have one from costco i have used to spray meany cars. I run 2 furnace fans at the back of it tho with filters on them to stop the over spray havent had a prob yet. done 10 cars in 6 years in my driveway.
NakeDiesel
oklahoma
I've got a large Garage in a Box that I will be setting up in my shop and covering with 6 mil as my paint booth. I've previously built sand blasting and paint booths out of PVC pipe and plastic drop cloths. Worked pretty well.
jpearson
I've used a similar tent from harbor freight. I'll dig up some pics this weekend. I framed up ends to hold the intake and output filters and a door. It works well but if you are doing a car the 10 width is pretty narrow. The HF tent is on sale now for $180 and if you find a 25% off coupon you can use that too.
I am painting a 911 in it. That tub is totally stripped and it's pretty small and it's a very tight fit.
gahrajmahal
Cincinnati, Ohio
Here ya go
http://www.jalopyjournal.com/forum/showthread.php?t=539437
I'm editing by adding a few points that relate to my link. If you suffer through my Jalopy Journal post you will realize the main challenge of using a portable garage to paint your car like I did is you are at the mercy of the weather. I had a 30 degree temperature variable while trying to paint my car. No painter in their right mind would attempt to get a quality paint job with that big a swing in temperature. I was doing this paint job in suburbia where they don't take kindly to temporary structures staying up for months at a time. My goal was to get the garage up, tape and paint the car and get it torn down again over the long Labor day weekend. I chose a simple method for finishing my car for that reason but the results are far below what I was going for. As a young man I sprayed many a car out in the open in my parents driveway. My new neighbors would never put up with all the fumes and overspray. To the OP, if you decide to go with this temporary paint booth I suggest you spend two days spraying your car. The first day is pull the car into the structure and get it all masked off and ready to spray. Get your products and spray gun ready ahead of time. Maybe even spray your sealer coat. The next day do your final wipe down with wax and grease remover before using your tack rag. Then spray the car in the early part of the day when it is more likely to be calm and the sun is not so hot. It is also good to be rested when spraying. That gun gets heavy holding it out over the hood, roof and trunk of the car.
Last and most important, wear your respirator!! The fumes from painting are very toxic and can have long term consequences.
Good Luck!
sberry
Brethren, Michigan
Its got to draw on it. This principle can be used in small garages by dividing in half if heat is needed, heating equipment and even wood stove in one half, paint in the other.
It pulls the corner tight when the fan is on and warm air from the ceiling comes in down draft fashion over the end wall. It clears really really well, as good or near as good as a commercial booth and most of the time I barely sweep the floor first.
I can reach and turn on the fan to save heat, you can feel the warm air move in when its turned on and when the building runs out of heat. Painting equipment is hard and slow, a car takes a 5 minute pass.
sberry
Brethren, Michigan
Mine actually works better since I slowed the fan a pinch, saves a lot of heat and I am not painting a lot of large jobs routinely anymore. It works so well there is no overspray on everything, it clears in the direction its sposed to.
Work truck type paint jobs mostly.
A
arturo7
huntington beach
Thanks for all the tips!
I found a place in LA that sells canopies that use 1-3/8 galvanized fence rail. 12 x 20 fully enclosed unit was $400 out the door. Bought some cheapo press board from HD for the flooring. It went together easily, seems sturdy enough. Haven't hung the sides yet.
View media item 33806
View media item 33807
