Nick_Wa
So I have my wiring complete in the garage (save for adding exterior lights and the interior lights). I still need to run main feed from house panel but want to check my panel is installed and setup correct right now.
I removed the copper clip that attached the neutral bar to the back of the panel. I assume this is what I needed to do so the neutral and ground weren't bonded.
I will be coming in with 3 gauge wire (3 conductor + ground) to feed 100 amps to the garage with 1.5" conduit coming in and up to box.
I also heard (and it doesn't appear to say specifically in my Ontario Code Simplified book) that we don't ground the box in the garage with ground rods but instead just have the ground being fed from the house panel which is grounded with rods as the main service entry? Any thoughts/clarification on this?
Thanks
Thanks
