I am swapping out some three way switches and got something mixed up. Going back to square one I pulled both switches. Both boxes have the same thing. No wire nuts, the red is hot, touching the red and black turns on the light.
I googled but the diagrams I come up with don't fit. Any one got something?
Did the 3 way switch circuit work properly before you changed them out ? Could you go to either switch and turn the fixture off and on from the selected switch ? Then, go to one switch and turn the lamp off and then walk to the other switch and turn it back on ? Maybe the switches never worked right before you decided to change them out ? This would explain why you cannot get them to work now. ...
If they worked properly BEFORE you removed the old switches, and if the feed (HOT) is entering the fixture, then it is just a matter of reading the schematic above and finding the traveler conductors. As stated above, there should not be two "hots" in a box....
Unless, maybe a metal staple over the cable on a stud was driven too tight, or a drywall nail /screw has finally cut in to the insulation between the HOT conductor and a traveler in the same cable making two hot conuctors. Take the voltage off the circuit and do continuity tests on each conductor to test their integrity. good luck
