Bulk wire storage
graymond
White Rock, BC
I am in the process of reorganizing the garage and I am finding that I need to store my spools of automotive wire in a more accessible fashion than in a box.
I thought about using a peg board and long pegs for each gauge.
Does anyone have a better idea?
Ray
MFolks
Springfield Mo.
If you can find a metal storage cabinet tall and deep enough & then run steel rods to hang the wire from. This way will keep dirt off the wires. Maybe something along the line of what women do for sewing machine thread spools.
If you want portability, look at getting or making a roll around cart, so it could be close to the car for ease of wiring.
boiler7904
NW IN
Depending on how many spools you have and what size they are, there are a few ideas here that could easily replicated at home
Wire Spool Storage Ideas
I have a portable Carlon wire caddy that hangs on the wall when I'm not wiring something around the house. It holds up to 8 500 ft spools.
92GreenYJ
San Diego, CA
I haven't done this yet, but my plan is to take the top deep drawer of my cabinet under my electrical bench. Drill some holes in each side and run dowel rods thru the drawer. Then place my spools on thei dowel rods to allow for easy access and dispensing.
kendogg
Auburn, GA
Use conduit and a couple pieces of wood and put them on a nice usable rack that you can just slide under the woorkbench when not in use.
astroracer
Mid_Michigan
Here are few pics of the wire spool I made to hold all of the wire I use while wiring the van.
This is pretty simple as it's only a heavy cardboard tube with dividers made from heavy cardbooard and hotglued in place... A scrap of 5/4 deck board made the base.
I put hooks in this and it hangs right over my wiring bench so the wire is easy to reach and stays out of the way.
When not being used I bag it and store it in a cabinet.
Mark
92GreenYJ
San Diego, CA
Not to hijack or anything but since we are on the subject, has anyone found a source online for EMPTY plastic wire spools? When I go to do my project mentioned above I would like to try and transfer some of my non spooled wire onto spools for this. Would also be nice to have spools all the same size.
lilredex
Toronto
If you or your friends use wire feed welders......the 2# refills have suitable spools and are free.
teamextreme
Lakewood, CO
Or make friends with a commercial electrican and have him save all the old spools. Or see if you can scavenge were they toss out old wire spools on a construction site (commercial not residential)
Responder
Saskatoon, SK
