Exhaust Fan Recommendations
zeebad1
Northern Illinois
I'm looking for suggestions for an exhaust fan for the shop.
I see the axial direct drive all the time, but they tend to be noisy, and leak cold air in the wintertime. I have been searching for powered shutters, but haven't found them yet. I would assume that they would seal better. With a variable speed controller, the noise could be reduced.
What about the inline fans? Has anyone tried those. Maybe a tube ductwork over the welding/fabrication area, and vent it out the endwall. I did find backdraft dampers for those.
What do you have that either works, or doesn't work for you.
s_ontario
canada
Build a box over the inside with doors just like a cabinet open them when you want fan running closed to conserve heat
just make sure fan won't pull the doors of cabinet closed when running
ersatzs2
Mercer County, New Jersey
Better yet, something I thought of recently that is similar, buy an 'explosion proof' fan and build it into a wall cabinet big enough to be a paint cabinet. Then whenever you have a quick paintjob you've got a ready space to do a quick spray wo stinking up the garage. Meanwhile you've got a powerful exhaust fan.
e-tek
Saskatoon, SK
I built one of these and it's been AWESOME. For the first time I have a spot to contain overspray, contain fumes (and the SMELL!), stays clean and can be heated in a few minutes with a little heater. Now, not one item in it is "Explosion proof" or "fire proof", but it does the job. Next one I build will be safer....maybe.
http://www.garagejournal.com/forum/showthread.php?t=24339&highlight=booth
As for a shop exhaust fan, I have "barn fan" with a reostat, but the louvres do let some air in/out. The door idea is GREAT too - thanks.
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
I was going to use gravity type louvers for a belt driven squirrel cage fan on my new shop but building a cabinet would conserve more heat. -Thanks Ontario!
kbs2244
Depending on how much air you want to move, I would think about a blower from a scrap clothes dryer.
It will hook right up to 4 inch duct work and you can use the dryer style outside flapper for keeping the wind out.
